Tv won't stay connected to wifi keeps connecting and disconnecting.
leeshez
Hi guys, Every day through out the evening whilst watching TV, It keeps saying TV is not connected to the internet then a couple of minutes later it reconnects. I have checked and it is connected to my network, Also i have reduced my router to 2.4G for the wifi signal. Also the router is about a foot from the Tv.
Thanks Lee.
62 REPLIES 62
Muffinman2k
go to help and it should be in the top right.
https://www.sony.co.uk/electronics/support/articles/00119543
Win_88
Specialist
@Liana.m Keep IPv4 enabled, but just to confirm, does your TV lose connection occasionally or does it not connect at all?
Liana.m
Thank you! I will try it- so it says it is connected this lasts seconds then by the time I’ve come out of the wifi options it says there’s no connection. So it lasts seconds then drops out
Win_88
Specialist
Try tethering to a hotspot or using Ethernet to better understand the problem
Dunhookin49
No it keeps getting and then losing signal. Stays on internet for a couple of minutes then loses connection for about 30 secs
Sent from my iPhone
Win_88
Specialist
I'd say if you confirm this happens regardless of the network you're using, contact Sony support and log a ticket with them about the issue.
kjus13
Has anyone found a fix? I started having this problem a couple of days ago as well, today it got to a point where the TV is unusable.
HannahEd01
Hey kjus13, what is the model number of your TV?
kjus13
My TV is KD55AG8BU.
IamNic
Hello @kjus13,
try to set the TV so it pulls the network time. This usually solves frequent disconnects.
- Nic
