Tv won't stay connected to wifi keeps connecting and disconnecting.
leeshez
Hi guys, Every day through out the evening whilst watching TV, It keeps saying TV is not connected to the internet then a couple of minutes later it reconnects. I have checked and it is connected to my network, Also i have reduced my router to 2.4G for the wifi signal. Also the router is about a foot from the Tv.
Thanks Lee.
62 REPLIES 62
kjus13
Thanks, @IamNic, that's the settings I've been using since always.
This whole problem started out of a sudden after nearly two years of flawless operation...
TrekMadone.
I changed my broadband supplier and got a new modem. It’s been fine since.
Sony tv is not compatible with all modems.
don’t bother with the help desks. Everyone blames each other!
I now have a plusnet modem. All good.
 Trek
Malbazz
Our sony tv frequently loses wifi connection.  Watching ITV catchup it returns to the start of a programme after the adverts.
profile.country.SE.title
jag_far_inte_heta_lilla_b
kan man inte byta wi fi adaptern till en starkare nyare? det skulle kanske lösa problemet ?
Tack för intressant lösning i alla fall.
izzzyinn
I have the Sony BRAVIA KD-65XH9296 the Tv was exchanged 2 times with different faults on the 3 tv the tv has trouble switching on pluss it freezes when using the remote ...!
Thehomme
Thanks. 100% agree. OF COURSE IT IS THE TV!!! Everything else works fine. I can’t believe someone suggests plugging in an Ethernet cable as a solution.
Thehomme
Update on this. I have a 3 disc BT whole home mesh system to extend wifi in my house.
What I discovered is that one of the discs (upstairs and not the one the TV was connected to) wasn't connected properly. It didn't cause any problems with any other devices but I rebooted the BT whole home system and I haven't had the issue since.
HannahEd01
Hi Thehomme, I'm glad to hear this. Thank you for updating the thread.
profile.country.BG.title
KrystoDobrev
I just want to thank you for your help, because it was your advice that helped me solve my problem!
HannahEd01
Hey KrystoDobrev, you just made my day! It was a collective effort. :slight_smile:
