Whatsapp sound and notification
manzoorm
I have tried everything from restoring previous data to reseting the notification on all apps .
I even tried unchecking the " play sound and selecting a new tone" within the whatsapp setting
The problem is " i have no sound or visual notification on the display bar" on the top of the screen for whatsapp.
Did anybody have a similiar problem with whatsapp notifications especially the sound part.
Any help would be appreciated
14 REPLIES 14
manzoorm
Is this correct
Uliwooly
@manzoorm
this is quite odd, do you have any third party notification apps or a different home launcher or lockscreen app?
manzoorm
Just a lock screen app called ' chatlock'
profile.country.PL.title
najodleglejszy
have you tried uninstalling or disabling this Chatlock app that you're talking about and see if you're getting notifications then?
manzoorm
Thanks it worked
