Whatsapp sound and notification
manzoorm
I have tried everything from restoring previous data to reseting the notification on all apps .
I even tried unchecking the " play sound and selecting a new tone" within the whatsapp setting
The problem is " i have no sound or visual notification on the display bar" on the top of the screen for whatsapp.
Did anybody have a similiar problem with whatsapp notifications especially the sound part.
Any help would be appreciated
1 ACCEPTED SOLUTION
profile.country.PL.title
najodleglejszy
have you tried uninstalling or disabling this Chatlock app that you're talking about and see if you're getting notifications then?
14 REPLIES 14
Uliwooly
@manzoorm
Settings > notifications > whatsapp > check the notifications
also, you could clear the app data or uninstall and reinstall the app.
najodleglejszy
can you go to Settings > Apps > Whatsapp > Notifications, take a screenshot and post here?
manzoorm
manzoorm
uliwooly this didnt work
Uliwooly
@manzoorm
Which part?
manzoorm
Both the options are not working
Uliwooly
@manzoorm
Whatsapp > menu > settings > notifications > take a screenshot.
manzoorm
Here u go
Uliwooly
@manzoorm
wrong screenshot
Open whatsapp > then follow the above instructions.
