Ringtone problem on Z3 Dual after Android 6 update
BitBull
Hello! After updating of my Sony Xperia Z3 Dual to Android 6 the ringtone vanishes, all other sounds works. Right after updating it has occurred next day, after reset of phone normally worked 7 days. Adjustment of level of ringtone doesn't reproduce a sound, as well as the choice or playing of the ringtone too.
The similar situation at me already arose after updating from version 4.4 on version 5.0.2 (http://talk.sonymobile.com/t5/Xperia-Z3/phone-not-ringing/m-p/983070#M16039). The situation has improved only after updating to version 5.1.1. I hope this time elimination of this problem won't take a lot of time!
13 REPLIES 13
KaL1
After installing marshmallow the device isn't ringing but I can answer and talk..
Uliwooly
@KaL1
check if you enabled do not disturbed
Ahmedmossaied
@Quester
The problem is after using headphone jack or casting by Bluetooth
Sounds like a mute
To back it working you should use do no disturb and switching between moods active mood or no just switch
profile.country.US.title
Qatrium
@Ahmedmossaied
Try clearing cache of Smart Connect app:
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data and restart your phone.
- Go to your Play Store and update Smart Connect again.
