My Z1 compact came with 4.4.4 build no. 14.4.A.0.108. And now I've got an update notification with same build number. Should I update it or not? Its 1gb in size or else I wouldn't have had second thoughts.
I have .108 and had a small .108 update so I updated assuming it was a minor tweak but no way was mine 1GB - Open Settings then Apps and swipe to All and locate Update centre and open then tap on Clear cache and Clear data and see if it's still there after a refresh of the app
I tried that. Still getting notification.
Don't suppose you have rooted your device or something like that as you would also get this notification
No I have not.
Pass then - You could go with the update or ignore it - Strange why you would have it in the 1st place
So you also have the .108 build version and also have an update to .108
Hey, even i got the update to the same build and when i tried to update, it failed. now i'm stuck in the update failed message which loops. i tried to use pc companion to repair the phone but even that fails and gives the same error message.
