I suffered a similar problem with my car head unit, what I've done was performing a software repair using PC Companion and then everything went fine. I didn't try any other solutions, but you can try un-pairing these devices, resetting them, and re-pair them again to see if this will work. If you decide the perform a software repair on your phone, bear in mind that this will erase your internal memory, so take a back up of your important data.
Hi Myller1986, I have a same issue with you. How do you fixed it? Thank you
