Vaio LT1M Display problems
jumpsuit
Hi all
My beloved 'desktop' has a problem.
I have all sorts of lines on the display.
I think it began with the pc shutting itself down the other night.
At first we thought it may have been
an overheating and checked the internal cpu - which showed 80 across the board
After taking the back off and cleaning vents and what parts of the fans were accessible,
I rebooted and all was well for a while - temps dropped back to 65-70 degrees.
After 5 minutes the lines reappeared and since then have appeared from startup even after a cold boot.
I'm now wondering whether its the graphics card itself. Didn't manage to locate it on first look inside it.
Any ideas without taking the back off again?
EDIT: Now worried that the Nvidia chip is incorporated into the motherboard. Can any users confirm this as his would mean a motherboard replacement.
2 REPLIES 2
Thalamus.
Champion
Hi Jumpy,
Doesn't look good, sounds like a chip problem to me and yes the NVidia GeForce 8400M GT is soldered to the mother board.. :slight_frown:
Blencogo
Hi Jumpy,
It looks like you have your own personal version of 'Space Invaders'.
Time to phone Vaio-Link before a queue forms!!!!!
:slight_frown:
