Performance CPU problems
adz32
I have a 2.4 Ghz Sony VAIO PCG-VRZ515G
It has really bad performace problems, I am a musician and so run some intensive software, and need the laptop for live performance.
When I start to run my music software, Cubase SX or Ableton Live, the computer slows down to a crawl - if I check, in Control Panel -> System the actual CPU speed, it starts at a normal 2.39 Ghz, and after running the software for a minute its slowed down to 882 Mhz. If I quit the software and go back its then 2.39 Ghz again.
I have been advised to clean out the air vents with compressed air, which I did, but this has only stopped it overheating, not the performance problems.
If I could afford it i'd sell it and get a Centrino, but for now I need to try and solve this with what i;ve got. A 2.4 Ghz processor should be flying along, but it seems slower than my old 700 Mhz Athlon machine.
Any help here much appreciated,
thanks,
adam.
28 REPLIES 28
nick_pan
wow im very impressed..
can u give me the exact model u got please :slight_smile: cause thats a very impressive temp drop..11 degs!!
in addition to my other cooling techniques, i think i could get my laptop running under 30 degrees :slight_smile:
ah exciting !
kee-lo_
Yeah I'm interested in the make and where you got it.
adz32
Got it from www.dabs.com, its the Antec notebook cooler.
nick_pan, what are your other cooling techniques?
Check this, i'm thinking of trying it:
http://www.ableton.com/forum/viewtopic.php?t=7941&start=15&postdays=0&postorder=asc&highlight=heatsi...
Also check this for a laugh!:
http://www.nativeinstruments.de/index.php?id=1576&upper=index.php?id=forum_us%26type=2&lower=forum/s...
kee-lo_
nick_pan
good ideas, cooling your laptop seriously should just come for an external cooler but what about other ideas?
im now thinking of getting a portable air con unit blowing at 16 degrees into the thing which should make it COLD. in addition to the laptop cooler i wanna get, i should have things sorted i mean just remember a cpu cooled to 0 degrees centigrade runs 40% faster. question is how u gonna get it down to 0??
the quest continues!
tellingd
I remember reading an article on this subject some time ago in a magazine. They supercooled the chip and managed a clock speed in excess of 5GHz :anguished:
Unfortunately, the rest of the hardware isn't designed to work at that kind of speed :thinking:
kee-lo_
Yep it was a fridge cooler they used and compressed air systems. Was very quiet too.
nick_pan
speeds of excess of than 5 ghz are done via the water cooling method but using liquid Nitrogen~ not applicable to laptops tho as the machine no longer becomes portable as it would need disecting :devil:
..a cooler that sits on the bottom is more than enough!
kee-lo_
Yes I remember seeing it on Tom's Hardware Guide.
