wireless internet problems
profile.country.sv_SE.title
lagtag
I just bought a Bravia KDL40EX720
I can´t get the wireless internet to work.
I says can´t find wireless USB.
i have a Netgear Wireless-N dual band WNDA3100v2.
Can anyone tell me why it doesn`t work, have I bought the wrong thing?
Bjorn in Sweden
1 ACCEPTED SOLUTION
Catmambo
Contributor
It doesn't have integrated Wireless so you need to connect either via Ethenet cable or purchase the Sony wireless dongle.
Hope this helps
3 REPLIES 3
Catmambo
Contributor
Hope this helps
Bravia55HX
Hi lagtag,
the Netgear wireless adaptor you bought will not work with this tv, you need the Sony UWA-BR100 or if wireless is not a priority use a lan cable.
Bravia55HX
i think Catmambo missed the fact that a Netgear wireless adaptor was being used here and thats why it would not work and that his answer does not carry enough merit!
