Hi. I have problem in the radio with the new software. The sound is not clear as it should be. Does anyone have an idea about this?
Dear Uliwooy & Johan,
It always happens with me indoors and in the same place. it does not have a relation to the coverage. After the first or second hour of use, the sound becomes kalsdy, I feel with disrruption and I can't hear the speach. Turning the mobile off and reopening the app. solve the problem for another one or two hours.
Thank you for trying helping me.
have you tried to repair your phone, can you elaborate on the issues?
Yes, Actually the repair has been performed in the company. and I have been informed that everything is Ok. Unfortunately, after 2 hours, I have faced the same problem.
can you elaborate on the problem? does this happen indoors? outdoors? etc?
So you're saying that the problem came back after 2 hours?
Could it have something to do with coverage? Do you get better quality if you try to use the radio on another location?
i solved it by removing the mcafee anti virus program.
Thank you. I have removed Mcafee but still have the same problem.
Do you mean the FM radio
read here http://talk.sonymobile.com/thread/43225?tstart=30
(not the cell radio or the bluetooth radio or the NFC radio or the wifi radio)
Ian
how about if you repair your phone and do NOT install any app at all
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
