Hello
i have live with walkman and i update it to ics
where is voice recorder in the apps list?
i want it and itisn't on my phone!:smileycry:
and it isn't available in the play store:smileysad:
what can i do?
this is a bad weakness:smileyangry:
Now do you know where can i find it?????:smileyconfused:
I also have the Live with Walkman and it does not come with a voice recorder (annoying isn't it?). I use a 3rd party one from the Play Store, I use Tape-a-Talk Voice Recorder its simple and has high quality recording.
https://play.google.com/store/apps/details?id=name.markus.droesser.tapeatalk&hl=en
Thanks for your help:smileywink:
but it shows voice recorder app in " /system/app "
the voice recorder pre-loaded it's to record short voice messages to be sent as MMS
unrelated topic, if you have some time please check this thread
Anytime
