Hello, I want to upgrade my xperia pro mk16i to ics 4.0.4. The update is already in the PC companion but in step 2 that is preparing the computer before the end the step 2 the update's stops and get a message that says it is impossible to upgrade does not reach step 3. I need help please!! Thanks
Let me know if it helps.
I install adb drivers first time i conected my xperia, unknown sources needs to be actived? or not? and the mode need to be MSC or MTP? i put them in two modes and nothing happens
Let it be in default mode ie MTP.
Unknown sources should be always be checked.
If adb drivers are installed uncheck USB debugging and then flash
Thank you all!! i updated my xperia pro
with sony update service.
But i have a problem when i entering a game this closes automatically and i can't play
help me!
Repair again with SUS, its better to format sd card and factory reset phone before updating.
i have a problem with ics when I turn off my phone and turn back the applications listed wisepilot, a game, uefa.com, etc and this application i deleted but return to the menu
Is your phone rooted.
No, my phone isn't rooted but the problem is fixed, thanks all
And one more question, What's the advantages of root?
if you root your phone you can use an app like titanium backup to remove bloatware not just disable it
