Problem with my xperia pro ICS update (PC companion)
Not applicable
Hello, I want to upgrade my xperia pro mk16i to ics 4.0.4. The update is already in the PC companion but in step 2 that is preparing the computer before the end the step 2 the update's stops and get a message that says it is impossible to upgrade does not reach step 3. I need help please!! Thanks
29 REPLIES 29
Not applicable
I checked that SI no. is listed. I wrote this in my above post.
Not applicable
One more question: if i update via flashtool the languaje of the phone will be spanish? and my operator in bolivia (tigo) will continue to work correctly?
Uliwooly
your operator will work just fine, and you can select spanish
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Not applicable
dont worry, everything will work fine. You can choose language anytime using settings.
Not applicable
thanks all!  i will try to update and i will tell you when i finish Smiling_Face_with_Sunglasses
Not applicable
One more thing i would like to tell you that i experienced more smoothness in generic firmware.
Not applicable
Maybe beacause it has less bloatwares.
Not applicable
I'm using flashtool but i cant update:
02/046/2012 07:46:46 - INFO - Device disconnected
02/047/2012 07:47:00 - INFO - Selected MK16i_4.1.B.0.431_Baltic.ftf
02/047/2012 07:47:00 - INFO - Preparing files for flashing
02/047/2012 07:47:22 - INFO - Please connect your device into flashmode.
02/048/2012 07:48:24 - INFO - Opening device for R/W
02/048/2012 07:48:25 - INFO - Start Flashing
02/048/2012 07:48:25 - INFO - Flashing loader
02/048/2012 07:48:25 - INFO - Ending flash session
02/048/2012 07:48:25 - ERROR -
02/048/2012 07:48:25 - ERROR - Error flashing. Aborted
02/048/2012 07:48:25 - ERROR - Drivers need to be installed for connected device.
02/048/2012 07:48:25 - ERROR - You can find them in the drivers folder of Flashtool.
02/048/2012 07:48:52 - INFO - Device disconnected
Not applicable
I downloaded the europe keyboard layout but i didn't know what i will need download for Bolivia
Download link (Europe keyboard layout) - https://rapidshare.com/files/9718140...431_Baltic.rar
Download link (Africa keyboard layout) - https://rapidshare.com/files/3422525...1251-0386_.ftf
Not applicable
In phone go to settings>security and check unknown sources.
Then go to developer options and check usb debugging then connect the device to computer and make sure PCC or flashtool not running in the background. It should install ADB Drivers for your device.
Now uncheck debugging and start the flashing process.
