Adobe Flash Player 11 on ICS 4.0.4.
Not applicable
I wonder, why I need to activate Flash Player 11 each time while browsing the internet on Xperia Mini Pro ICS 4.0.4.?
Why it cannot be activated by default, ie after installing Flash Palyer Application I performed after updating on ICS 4.0.4.?
With Gingerbread, flash player was activated as soon as I visit some web page, i did not need to click on green arrow.
1 ACCEPTED SOLUTION
m4dj
Hm. I am using Dolphin browser an there the flash support is always enabled if you check in options, so the flash will works immediatelly uppon visiting the web page that requires flash.
Try Dolphin browser or try to go into your browser under the options - advanced - check enable plugins = always on.
3 REPLIES 3
m4dj
Not applicable
That's it, thank you very much. It wasn't checked in browser settings.
Not applicable
i think ICS will not support flash player anymore... so if I were you, i am not going to DL flashplayer anymore.. just a waist of memory... Neutral_Face
i think that ICS has already a build in Flash:smileyconfused:
