Dear One and All.
My apologies up front if this question sounds stupid. I have just bought a KDL-37EX403 along with a BDP S380 Blu [DVD player] and I am having a few problems trying to set-up the various cables/links into the back of my set. I also have a Humax FreeSat HDR and a B&O VCR.
1) When linking in the DVD player and the SatBox, which both use HDMI cables, is there a preference into which HDMI socket they are plugged ?
2) As the VCR player only has a scart lead I assume it should be linked into the scart 2 connection.
3) Having linked these items up I would like to be able to set the sound levels across the TV/SatBox/DVD/VCR to all be the same and not have to use the various hand-sets to adjust each one everytime.
4) I have noticed already that sometimes I can hear in the background some broadcasting from another source at the sametime as watching the Humax programmes.
5) I have also tried downloading the Firmware update but when inserting my USB device - Nothing happens
Regards
David in Guildford
Message was edited by: dsc8wilson
Welcome to the forums
With regards to the firmware, make sure you don;t extract the file from the folder it creates after unzipping. You need to have e.g. G:\original folder name\file name - so the TV sees the folder and the file, if that makes sense.
