i have connected my sony tv and humax freesat+ box to a sony ht-as5 surround sound but when i select a hd channel the volume is much higher any help please
go into options- sound- scroll down to volume offset and click on that, select the correct input for the freesat box, for example HDMI 1 then back off the volume there until you get it where you want.
