Hello
My soundbar is playing up. I get a muted sound from the bass unit but NO sounds at all from speaker bar itself. I've tried a system reset with no luck, and the optical cable seems ok (no damage, and red light visible).
Any ideas please
Thank you
Hi there,
The first step in the troubleshooting process is a factory reset.
Once done, check to see if the cables are connected properly and then set it back up again. If this doesn't work, let us know.
Best wishes,
M
