WHERE CAN I GET A REPLACEMENT REMOTE CONTROL FOR MY DVD RECORDER
Try the customer support line - details at the top of the page or your local service centre should be able to order one for you.
Failing that, there are 3rd party or universal remotes available on ebay etc.
E bay is a good a place as any, type the model number of the remote in the search bar and you should get a few come up, or google it and see what pops up.
Catmambo,
there are also genuine Sony ones on there too!
