DSC-TX30 Firmware for English language menu
A japanese student brought me a DSC-TX30 but the language is japanese only. The [. . Menu - Settings - Main settings - Language settings. . ] doesn't have an english option. Is there any way of updating firmware or changing this so we have an english language set. What software do I need to flash the camera via the Micro-USB
1 ACCEPTED SOLUTION
Nobody-in-particular
Contributor
Hi McScotsman, The languages that are available are usually the ones that are used in the region where the camera was purchased and I am almost certain that it is not possible to add additional language packs, etc to your Camera.
@Agnieszka_J wrote:
I have however escalated your issue to Support and once we have a confirmation of that, someone will contact you directly.
@Agnieszka_J  I don't think it is possible to add additional languages but seeing as you are getting confirmation I wondered if you would be able to also update this thread with Supports response because I am sure that the answer would be useful to other people.
2 REPLIES 2
profile.country.PL.title
Agnieszka_J
Moderator
Dear McScotsman,
I believe these cameras are locked to the region in which they were sold, so it might not be possible to add the English language option to this particular one. I have however escalated your issue to Support and once we have a confirmation of that, someone will contact you directly.
With kind regards,
Agnieszka_J
Contributor
