cannot connect my iphone 5 to my rx100M2 ...finds it ok, when you start PMM, it searches then resonds with unknown error found
shame as I'd relly like to use the phone as a remote control!
at least I've an eyefi card to allow wifi transfers!
PS this rx100 M2 is producing results on a par with my nex7.....marvellous wee camera!
All sorted.....turns out I'm a dope and was using an odd wifi protocol on my phone...works a treat now!
sony....all forgiven!
Oh, By the way, same problem with a non-eye-fi card too so not that!
