My Sony tv wired Ethernet is not working.
Woodie82
Oreo update done on KD-65XE9005 and since this update the tv keeps stating ‘Ethernet is not connected’ and I can not use tv as for you tube Netflix etc.
I have tried a soft soft reset and it doesn’t work.
can anybody assist? Thanks
22 REPLIES 22
profile.country.IT.title
Marino.Manolo
Have you tried simply to disconnect and reconnect the Ethernet cable?
Manolo
Woodie82
Evening,
yes tried that numerous times works for 20minutes then get a repeat of the message and won’t work.
Marino.Manolo
Sorry if I ask but, of course, also Router side? And ... have you tried a reboot of the router?
Manolo
Woodie82
No worries
yes tried connecting reconnecting Ethernet both sides and router reset about 2hours ago
Kink43
I also have this problem since Oreo update.
I only use the TV for online features so is a little frustrating.
Is it likely to get patched to resolve the issue?
Woodie82
They issued a patch and it has not resolved my issue.
Now been asked to try WiFi connection, hotspot connection and direct Ethernet wired connection with no splitters thus far no fix.
After months of trying to fix it I’m not hopeful of any sort of solution.
Sent from my iPhone
LGSAMy
Have you tried turning off IPv6 on your router ? Seems to solve a lot of connection issues . Did for me anyway .
Kink43
My brother suggested setting a static IP on the TV rather than allowing DHCP to dish out the address.
Fingers crossed have been a whole day and not seen the 'ethernet is not cnnected' message.
rickyip49
Hiya,
I’ve got the same issue since the Oreo update.
Can I ask what modem/router you have please?
Just wondering what info you used when you chose “static” on the TV. It’s asking me for all sorts like dns etc etc.
Any help much appreciated!
