Good morning, I have problems with my Sony Xperiaz5 is constantly restarted and the wireless network is disconnected .. I have gone to technical centers and have updated the software but nothing works .. Someone could help me indicating what happens and what solution there may be ..
Buenos días, tengo problemas con mi Sony Xperiaz5 se reinicia constantemente y se desconecta la red inalambrica .. He ido a centros técnicos y le han actualizado el software pero nada funciona .. Alguien me podría ayudar indicando que sucede y que solución puede haber ..
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Remove the SIM and SD cards, see if you experience the same issue, if you don't then you have a faulty card.
