Sony XZ Poor Signal Strength / Reception.
Barton
Just received my new Sony XZ, and my first call hung up twice due to poor signal strength. Switched back to my older Z3+, worked perfectly, call completed no problems. Even my M2 worked better.
Consistently no bars or 1 bar on 4G network setting. Switch to 2G then you may get 3 bars.
What is going on?
Tags (3)
2 REPLIES 2
nesligun
I have same problem with my Phone, too. I generally use 4G settings and there is mostly just one bar, sometimes none. It is really annoying. I wonder how I can fix this problem. I tried software repair, it didn't work.
profile.country.ES.title
fercrego
It happens the same to me since last system update Slightly_frowning_Face
