some days ago I got my new Xperia XZ Professional and I like it a lot ๐
Yesterday, I finished the installation of all of my apps and encountered a really strange problem: With only some app data on my SD card, everything was fine. But after finishing my installation, I had reboots, when my network connection changed! This ony happens, when an SD card is inserted and the problem is reproducible. Test setting:
1. Disable Wifi on router or disable Wifi on phone via settings
2. After about ten seconds, the phone reboots
3. Remove SD card
4. Try point 1 again, no problem
5. Reinsert SD card
6. Same problem as before
I'm on Android 7.1.1 build number 45.0.A.1.229 and my sd card is a Lexar Professional 128GB High-Performance Class 10 UHS-I 600x 95MB/s Micro SDXC card. Here's the output of a exfatfsck under linux:
exfatfsck 1.2.5
WARN: volume was not unmounted cleanly.
Checking file system on /dev/sdb1.
File system version 1.0
Sector size 512 bytes
Cluster size 128 KB
Volume size 119 GB
Used space 70 GB
Available space 50 GB
Totally 880 directories and 42723 files.
File system checking finished. No errors found.
And a 'df -h' shows:
Filesystem Size Used Avail Use%
/dev/sdb1 120G 70G 50G 59%
As you can see, the sd card is heavily used, but this shouldn't be a problem. The warning about the unclean unmount is due to the sudden reboot of the phone, but the filesystem is consistent.
A 'adb logcat' before a reboot did not give me any insghts about the cause of the problem. But I'm not an Android programmer... perhaps I missed the essential messages due to inexperience in Android device debugging.
Any hint how to solve this strage issue would be appreciated!
With the logs from my last entry, my current theory is the following: My initial attempt to encrypt the card was around the reboot issues I had (the beginning of this thread). As a result, the information on the internal storage got corrupted somehow and the system still thinks, that parts of the SD card are encrypted and parts of the SD card file access permissions got corrupted as well.
So I did a software repair with the Xperia Companion to get a complete new install (and not just a factory reset). I did this with the SD card in place (and intentionally not reformatting it). Before I made a backup of the system (everything available) with the "Backup & Restore" app of the phone (target: SD card). After the software repair I let Google Play reinstall all my apps and restored everything available with "Backup & Restore".
Now everything is back to normal again and I can access the SD card from all apps (Spotify, MAPS.ME, etc.) without problems.
I will follow up on this topic when I find the time to look at the logs - please give me some days ๐
Just for reference and maybe it will help someone in a similar situation.
Intermediate answer to my problems: Seems that deleting all Spotify songs from my external SD card solved the problem with the reboots after a network change.
As a consequence, I reformatted the SD card and restored a backup of the contents. After that the SD card had a new name (seems to be generated randomly in the format XXXX-XXXX). Long story short: Some apps recognized the newly formatted SD card automatically (f.ex. Camera app), for some I had to change the path in the app settings manually (same as before) and some stopped working / don't recognize the SD card correctly / cannot write to the SD card anymore (f.ex. Sygic, MAPS.ME, Amazon Music).
Someone with similar experiences here?
OK, here we go:
Would be nice to get an answer from a support team member! Perhaps a suggestion what I could try to find the source of the remaining problem (second point) or some fix ๐
And please don't suggest to do a factory reset of the phone - I know that this would most certanly fix my second problem for the moment. But things like that shouldn't happen at all - so I'd like to know the reason why ๐
Summary of the last two days:
I tried everything that came to my mind in the last 2 days, but couldn't find a solution for some apps not recognizing my sd card after a reformat. Here's a short recapture of the problem with Spotify as an example:
Ok, here's my daily post about this issue - no solution yet, but some more insight (maybe):
I looked at the debug logs of another app that's not working after reformatting my sd card: MAPS.ME - and here's the output:
06-14 20:08:47.141 I/com.mapswithme.maps.settings.StoragePathManager(32201): Additional storage path: /storage/3262-3632/Android/data/com.mapswithme.maps.pro/files 06-14 20:08:47.141 I/com.mapswithme.maps.settings.StoragePathManager(32201): Parsing /etc/vold.conf 06-14 20:08:47.142 W/StorageUtils(32201): Can't read file: /etc/vold.conf 06-14 20:08:47.142 W/StorageUtils(32201): java.io.FileNotFoundException: /etc/vold.conf (No such file or directory) 06-14 20:08:47.142 W/StorageUtils(32201): at java.io.FileInputStream.open(Native Method) 06-14 20:08:47.142 W/StorageUtils(32201): at java.io.FileInputStream.<init>(FileInputStream.java:146) 06-14 20:08:47.142 W/StorageUtils(32201): at java.io.FileInputStream.<init>(FileInputStream.java:99) 06-14 20:08:47.142 W/StorageUtils(32201): at java.io.FileReader.<init>(FileReader.java:58) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StorageUtils.parseMountFile(StorageUtils.java:94) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StorageUtils.parseStorages(StorageUtils.java:140) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StorageUtils.parseKitkatStorages(StorageUtils.java:166) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StoragePathManager.updateExternalStorages(StoragePathManager.java:158) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StoragePathManager.updateExternalStorages(StoragePathManager.java:150) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.StoragePathManager.startExternalStorageWatching(StoragePathManager.java:103) 06-14 20:08:47.142 W/StorageUtils(32201): at com.mapswithme.maps.settings.MapPrefsFragment.onAttach(MapPrefsFragment.java:219) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.Fragment.onAttach(Fragment.java:1454) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:941) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.FragmentManagerImpl.moveToState(FragmentManager.java:1175) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.BackStackRecord.run(BackStackRecord.java:816) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.FragmentManagerImpl.execPendingActions(FragmentManager.java:1589) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.FragmentController.execPendingActions(FragmentController.java:371) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.Activity.performStart(Activity.java:6740) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2683) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2781) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.ActivityThread.-wrap12(ActivityThread.java) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1508) 06-14 20:08:47.142 W/StorageUtils(32201): at android.os.Handler.dispatchMessage(Handler.java:102) 06-14 20:08:47.142 W/StorageUtils(32201): at android.os.Looper.loop(Looper.java:241) 06-14 20:08:47.142 W/StorageUtils(32201): at android.app.ActivityThread.main(ActivityThread.java:6281) 06-14 20:08:47.142 W/StorageUtils(32201): at java.lang.reflect.Method.invoke(Native Method) 06-14 20:08:47.142 W/StorageUtils(32201): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886) 06-14 20:08:47.142 W/StorageUtils(32201): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776) 06-14 20:08:47.142 I/com.mapswithme.maps.settings.StoragePathManager(32201): Parsing /etc/vold.fstab 06-14 20:08:47.148 I/com.mapswithme.maps.settings.StoragePathManager(32201): Parsing /system/etc/vold.fstab 06-14 20:08:47.149 I/com.mapswithme.maps.settings.StoragePathManager(32201): Parsing /proc/mounts 06-14 20:08:47.153 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/runtime/default/3262-3632 06-14 20:08:47.153 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.143 W/withme.maps.pro(32201): type=1400 audit(0.0:546): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:547): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:548): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:549): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:550): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:551): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:552): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:553): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:554): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:555): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:556): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:557): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.154 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/media_rw/3262-3632 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:558): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:559): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:560): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.154 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:561): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.155 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/runtime/read/3262-3632 06-14 20:08:47.155 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.155 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /storage/sdcard1 06-14 20:08:47.155 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.156 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/secure/asec 06-14 20:08:47.156 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.156 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/media_rw/3262-3632.exfat 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:562): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:563): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:564): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:565): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:566): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:567): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.156 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.157 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /mnt/runtime/write/3262-3632 06-14 20:08:47.157 I/com.mapswithme.maps.settings.StoragePathManager(32201): Try to create MWM path 06-14 20:08:47.157 I/com.mapswithme.maps.settings.StoragePathManager(32201): Test storage from config files : /storage/3262-3632 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:568): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:569): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:570): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:571): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:572): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:573): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:574): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.166 I/com.mapswithme.maps.settings.StoragePathManager(32201): Storage found : /storage/emulated/0, size : 38909706240 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:575): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:576): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:577): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.153 W/withme.maps.pro(32201): type=1400 audit(0.0:578): avc: denied { getattr } for path="/mnt/media_rw" dev="tmpfs" ino=21872 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:mnt_media_rw_file:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main" 06-14 20:08:47.169 I/com.mapswithme.maps.settings.StoragePathManager(32201): Storage found : /storage/emulated/0, size : 38909706240
As you can see from the first line, the app path on the SD card could be found correctly:
But there seems to be a problem writing to the path (access denied):
Well, I don't know how the normal behavior should be - I checked that I granted the app all necessary rights (especially storage). But it's the same as with Spotify - the menu point to save the data to sd card just isn't there... I already reported the problem to MAPS.ME.
Is here somebody here in the forum who can make a bit more sense about the relevant messages in the log?
And some more logs from starting Spotify this time (after app force close/purge app cache/purge app data and granting necessary rights manually):
Excerpt of adb logcat output filtered by "com.spotify.music":
06-14 22:04:15.431 3200 3345 I ActivityManager: Start proc 27315:com.spotify.music/u0a178 for activity com.spotify.music/.MainActivity
06-14 22:04:15.532 20116 20116 D KP2AAF : event: 2048, package = com.spotify.music
06-14 22:04:15.548 20116 20116 D KP2AAF : event: 32, package = com.spotify.music
06-14 22:04:15.637 20116 20116 D KP2AAF : event: 2048, package = com.spotify.music
06-14 22:04:15.888 3200 4756 D VoldConnector: SND -> {91 volume mkdirs /storage/3262-3632/Android/data/com.spotify.music/cache/}
06-14 22:04:16.247 27315 27315 W m.spotify.music: type=1400 audit(0.0:1826): avc: denied { write } for name="com.spotify.music" dev="ecryptfs" ino=17437088 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:ecryptfs:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main"
06-14 22:04:16.247 27315 27315 W m.spotify.music: type=1400 audit(0.0:1827): avc: denied { write } for name="com.spotify.music" dev="ecryptfs" ino=17437088 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:ecryptfs:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main"
06-14 22:04:16.247 4753 4753 W Binder:3200_B: type=1400 audit(0.0:1828): avc: denied { read open } for path="/mnt/media_rw/3262-3632.exfat/Android/data/com.spotify.music" dev="mmcblk0p1" ino=17437088 scontext=u:r:system_server:s0 tcontext=u:object_r:vfat:s0 tclass=dir permissive=0 ppid=2732 pcomm="main" pgid=3200 pgcomm="system_server"
06-14 22:04:16.258 3200 4753 D VoldConnector: SND -> {92 volume mkdirs /storage/3262-3632/Android/data/com.spotify.music/files/}
My current mountpoints:
G8141:/ $ mount rootfs on / type rootfs (ro,seclabel,size=1802908k,nr_inodes=450727) tmpfs on /dev type tmpfs (rw,seclabel,nosuid,relatime,size=1893892k,nr_inodes=473473,mode=755) devpts on /dev/pts type devpts (rw,seclabel,relatime,mode=600) proc on /proc type proc (rw,relatime,gid=3009,hidepid=2) sysfs on /sys type sysfs (rw,seclabel,relatime) selinuxfs on /sys/fs/selinux type selinuxfs (rw,relatime) debugfs on /sys/kernel/debug type debugfs (rw,seclabel,relatime) none on /acct type cgroup (rw,relatime,cpuacct) none on /dev/stune type cgroup (rw,relatime,schedtune) tmpfs on /mnt type tmpfs (rw,seclabel,relatime,size=1893892k,nr_inodes=473473,mode=755,gid=1000) none on /config type configfs (rw,relatime) none on /dev/memcg type cgroup (rw,relatime,memory) none on /dev/cpuctl type cgroup (rw,relatime,cpu) none on /dev/cpuset type cgroup (rw,relatime,cpuset,noprefix,release_agent=/sbin/cpuset_release_agent) pstore on /sys/fs/pstore type pstore (rw,seclabel,relatime) none on /sys/fs/cgroup type tmpfs (rw,seclabel,relatime,size=1893892k,nr_inodes=473473,mode=750,gid=1000) none on /sys/fs/cgroup/memory type cgroup (rw,relatime,memory) tmpfs on /tmp type tmpfs (rw,seclabel,nosuid,relatime,size=1893892k,nr_inodes=473473,mode=755) /dev/block/dm-0 on /system type ext4 (ro,seclabel,relatime,discard,data=ordered) /dev/block/bootdevice/by-name/oem on /oem type ext4 (ro,seclabel,relatime,data=ordered) /dev/block/bootdevice/by-name/cache on /cache type ext4 (rw,seclabel,nosuid,nodev,noatime,discard,data=ordered) /dev/block/bootdevice/by-name/appslog on /rca type ext4 (rw,seclabel,nosuid,nodev,noexec,noatime,discard,data=ordered) /dev/block/bootdevice/by-name/diag on /idd type ext4 (rw,seclabel,nosuid,nodev,noexec,noatime,discard,data=ordered) /dev/block/bootdevice/by-name/Qnovo on /qns type ext4 (rw,seclabel,nosuid,nodev,noexec,noatime,discard,data=ordered) /dev/block/bootdevice/by-name/persist on /persist type ext4 (rw,seclabel,nosuid,nodev,relatime,data=ordered) /dev/block/bootdevice/by-name/dsp on /dsp type ext4 (ro,seclabel,nosuid,nodev,relatime,data=ordered) /dev/block/bootdevice/by-name/modem on /firmware type vfat (ro,context=u:object_r:firmware_file:s0,relatime,uid=1000,gid=1000,fmask=0337,dmask=0227,codepage=437,iocharset=iso8859-1,shortname=lower,errors=remount-ro) /dev/block/bootdevice/by-name/bluetooth on /bt_firmware type vfat (ro,context=u:object_r:bt_firmware_file:s0,relatime,uid=1002,gid=3002,fmask=0337,dmask=0227,codepage=437,iocharset=iso8859-1,shortname=lower,errors=remount-ro) /dev/block/bootdevice/by-name/LTALabel on /lta-label type ext4 (ro,context=u:object_r:lta_label:s0,nosuid,nodev,noexec,noatime,data=ordered) tmpfs on /storage type tmpfs (rw,seclabel,relatime,size=1893892k,nr_inodes=473473,mode=755,gid=1000) tracefs on /sys/kernel/debug/tracing type tracefs (rw,seclabel,relatime) adb on /dev/usb-ffs/adb type functionfs (rw,relatime) securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime) /dev/block/dm-1 on /data type ext4 (rw,seclabel,nosuid,nodev,noatime,discard,noauto_da_alloc,data=ordered) /data/media on /mnt/runtime/default/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,multiuser,allow_utime_grp) /data/media on /storage/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,multiuser,allow_utime_grp) /data/media on /mnt/runtime/read/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,multiuser,allow_utime_grp) /data/media on /mnt/runtime/write/emulated type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,multiuser,allow_utime_grp) /dev/block/vold/public:179,1 on /mnt/media_rw/3262-3632.exfat type texfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1023,gid=1023,umask=0007,allow_utime=0020,utf8,min_prealloc_size=64k,max_prealloc_size=121910k,writeback_boundary=4M,readahead=4M,fail_safe,discard,hidden=show,errors=continue) /mnt/media_rw/3262-3632.exfat on /mnt/media_rw/3262-3632 type ecryptfs (rw,relatime,ecryptfs_sig=df437334546623b0,ecryptfs_cipher=aes,ecryptfs_key_bytes=32,ecryptfs_enable_filtering,ecryptfs_passthrough,ecryptfs_unlink_sigs) /dev/block/vold/public:179,1 on /mnt/secure/asec type texfat (rw,dirsync,nosuid,nodev,noexec,relatime,uid=1023,gid=1023,umask=0007,allow_utime=0020,utf8,min_prealloc_size=64k,max_prealloc_size=121910k,writeback_boundary=4M,readahead=4M,fail_safe,discard,hidden=show,errors=continue) /mnt/media_rw/3262-3632 on /mnt/runtime/default/3262-3632 type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,allow_utime_grp) /mnt/media_rw/3262-3632 on /storage/3262-3632 type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,allow_utime_grp) /mnt/media_rw/3262-3632 on /mnt/runtime/read/3262-3632 type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,allow_utime_grp) /mnt/media_rw/3262-3632 on /mnt/runtime/write/3262-3632 type sdcardfs (rw,nosuid,nodev,noexec,noatime,uid=1023,gid=1023,allow_utime_grp)
Hi @Kareema sorry to hear about your problem. You've done a really good job with investigation so far, my apologies for not seeing it earlier.
Do you regularly access the SD-card directly from PC or was that mainly because of this investigation?
The first crash is really interesting, but let's focus on your current situation first. I can't say that I've heard of this problem before and unfortunately I can already say that I currently don't have the solution at hand. Let's see what we can learn together.
One thing I know is that the XXXX-XXXX card name is kept if you move the card to another phone. So it's not that random, but kept on the card as a "unique identifier". Would be interesting to see if it could be renamed. Actually I didn't think it would get new name from a "format".
Did you format the external card in the phone or PC?
Did you try installing Spotify new on the phone with the External Card clean formatted (not restored backup)? You said "reactivating the app" so I wasn't sure if that was a clean install or not.
Was the backup you have created before or after the first crash (and FS corruption/repair)?
Do you have another phone where you can insert the SD-card and see what happens with Spotify there?
If we could clarify how the problem relates to "this phone", "the new card name", "the backup content" separately I think that could help.
> created on both internal storage and sd card, but there's no option in Spotify to select the external sd card as storage
The Spotify page said that they hide the option if the card is corrupt or missing. It's confusing that folders are created, but still not accessed.
On the other hand it seems to be Vold rather than Spotify that does the actual mkdir. Vold is a system process with special rights and it could be allowed even if app is denied access.
06-14 22:04:15.888 3200 4756 D VoldConnector: SND -> {91 volume mkdirs /storage/3262-3632/Android/data/com.spotify.music/cache/} 06-14 22:04:16.247 27315 27315 W m.spotify.music: type=1400 audit(0.0:1826): avc: denied { write } for name="com.spotify.music" dev="ecryptfs" ino=17437088 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:ecryptfs:s0 tclass=dir permissive=0 ppid=2733 pcomm="main" pgid=2733 pgcomm="main"
The "avc: denied" is controlled by kernel "SELinux rules". All installed apps are "untrusted_app" (with rather limited permissions) and I suspect that the denial is all according to plans here. So a bit of a question why it worked first time and what changed since then.
Did the following log continue successful, or with similar "avc: denied" there?
06-14 22:04:16.258 3200 4753 D VoldConnector: SND -> {92 volume mkdirs /storage/3262-3632/Android/data/com.spotify.music/files/} ...
The interesting part is that (if they access it correctly) the app should have access rights to "their own" data under "Android/data/com.spotify.music/". If it could access the "files" but not "cache" it could be due to encryption.
In your mount list everything looks good, but I didn't have this one:
Do you know what created that mount?
Can you run these commands and post the output? We want to see that the file permissions looks ok.
adb shell ls -l /storage/*-*/Android/data/com.spotify.music/*
adb shell ls -l /storage/self/primary/Android/data/com.spotify.music/*
Camera app is pre-installed and given special rigts.
Did you have any interesting app examples here? Perhaps there's a pattern to see.
I'm not familiar with the app, but the log looks a bit like a mess. I guess it's trying all kinds of things to work on as many platforms as possible, but I think it's correct to block several of those attempts for an "untrusted_app".
It's not exactly clear from the logs what happens, but reading directly at /storage/3262-3632 may be off limits. The "new way" is to ask the system for a private path.
https://stackoverflow.com/questions/5694933/find-an-external-sd-card-location
Can you screen shot that for reference?
Hmm. I understand your thought, but we may end up there eventually. Less work now than later...
// Jens
Hi @JensG
I'm glad to have somebody to talk about this issue - thank you very much! Here are the answers to your questions - hope this helps a bit to find a solution ๐
I nearly never use the SD card directly on my computer - only for investigation of issues or for restoring data. Backup of all accessible files on the phone is done via SSHdroid and rsync to my BackupPC server on my network via Wifi ๐
Well, I was a bit surprised as well: Every reformat on the device results in a new label - I tried it several times with the same SD card.
I tried both at first - but to have reproducable results, the last few reformats were done on the phone.
I tried both: I "reinstalled" Spotify after a clean format of the SD card and after restoring a backup of the SD card.
As Spotify comes pre-installed on the Xperia XZ Premium, "reinstall" means deactivating and reactivating the app (sorry for the confusion, hope you can understand what I mean). For reproducability, my normal procedure now with all the apps I investigate in regard to this issue is the following:
Unfortunately, the backup was made after the first crash. But as I tried the same with a newly formatted SD card, this isn't the root of the problem.
Sorry, no phone with an external SD card slot ATM.
I already tried to narrow down the problem - here my thoughts about it:
Here are the spotify related logs after the timestamp:
Time to remember some additional info: Before my initial problems with the network connectivity related reboots occured, I tried to encrypt my external SD card. Since then I decrypted the SD card (and never tried to encrypt the data on the SD card again), deleted most of the files on the SD card, reformatted the SD card several times (with and without restoring the data), replaced the SD card with a new one.
But it's not impossible, that the first encryption of the SD card triggered a bug... something to keep in mind!!
Yes, that's something that I found strange as well! The name "3262-3632" corresponds to my newly bought SD card (SanDisk Extreme 128 GB). This card was never encrypted! So I wouldn't expect an ecryptfs entry in the mount output. The device security settings say, that the SD card encryption is deactivated.
No, not really - see my comments above ๐
As you wanted to see the permissions, I modified the ls parameters slightly to show file and SELinux permissions ๐
~$ adb shell ls -alZ /storage/*-*/Android/data/com.spotify.music/*
/storage/3262-3632/Android/data/com.spotify.music/cache:
total 512
drwxrwx--x 1 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 131072 2017-06-16 17:52 .
drwxrwx--x 1 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 131072 2017-06-16 17:52 ..
/storage/3262-3632/Android/data/com.spotify.music/files:
total 512
~$ adb shell ls -alZ /storage/self/primary/Android/data/com.spotify.music/*
/storage/self/primary/Android/data/com.spotify.music/cache:
total 24
drwxrwx--x 3 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 4096 2017-06-16 17:54 .
drwxrwx--x 4 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 4096 2017-06-16 17:52 ..
drwxrwx--x 3 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 4096 2017-06-16 17:54 video
/storage/self/primary/Android/data/com.spotify.music/files:
total 24
drwxrwx--x 3 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 4096 2017-06-16 17:52 .
drwxrwx--x 4 u0_a178 sdcard_rw u:object_r:sdcardfs:s0 4096 2017-06-16 17:54 spotifycache
~$ adb shell ps -Z | grep spotify u:r:untrusted_app:s0:c512,c768 u0_a178 6599 2769 1970136 120156 0 0000000000 S com.spotify.music ~$ adb shell id u0_a178 uid=10178(u0_a178) gid=10178(u0_a178) groups=10178(u0_a178), context=u:r:shell:s0
Woah! How ignorant of me ๐
I checked these apps only by starting them briefly, but didn't redownload contents. In fact, even those apps that are configured with a static path on the SD card can't access their private directory for writing! Here are some examples of these apps: OruxMap, Aedict, AnkiDroid
OK, but that was once again with a restored backup of the SD card contents; so let's delete the contents of the "Android" folder and the empty ".android_scure" folder on the SD card this time (don't want to initiate a renaming of the SD card name this time). Done on my Linux laptop. Result:
Aedict3 says it can't create the directory /storage/3262-3632/Android/data/sk.baka.aedict3/files/ on the sd card. I created it manually and tried again. This time the error is:
Aedict3 trying to download dictionaries
And here's the adb ls output for the directories:
And the user Aedict3 is running under:
Hmm, strange indeed... "rwx" rights of the dirs for u0_a218 are right... and the app rights for storage have been granted (like in the picture for Spotify further down).
Well it's getting late here in Germany - so I'll stop at this point. If I can help with more logs/info/etc. please let me know! I really want to know what's the source of this strange problem!
Here's the last point you asked about (sorry, did't switch language to English - "Speicher" means "storage":
App rights for Spotify
Ok, to sum it up: Most apps (not including system apps) are unable to access their private path under Android/data/ on the SD card. I do not say "all" because I didn't test all apps yet. The directory rights checked via adb and ls seem to be correct and correspond to the user ids of the running process of the app.
It starts to get really interesting! Well I would be happy if you could spare some more time to debug this strange behaviour... ๐
Best regards
- Kareema
UPDATE: adb-log of Aedict3 start:
BTW: Before the problems with the sd card started, I could download the dictionaries to the external SD card without problems (to /storage/XXXX-XXXX/Android/data/sk.baka.aedict3/files/ with the correct XXXX-XXXX at that time).
Just tried to copy a file from internal storage to the SD card with X-plore file manager. I was asked to grant rights to write to the SD card and it was working without problems.
