How do I block applications from using mobile data
Dlip
I would like to know is there a way allow apps to use only data through wifi... And restrict them from using mobile data...
Thank you
1 REPLY 1
Uliwooly
@Dlip
Settings > data usage > cellular data usage > select each app > disable background data
