Autorotation seems to be a problem to with 7.0 dat still was not fixed.after watchin video's in movie app oqg draw allot in album i nee to switch on and off the rotation setting to fix.hope sony fix it before release 7.1.1 update.
What model of Xperia XZ are you using?
I tried on my Xperia XZ F8332 with Malaysia and India firmwares and is the same, the auto rotation is crazy and works sometimes.
But, friends with Xperia XZ F8331 tell me that this issue isn't present... (Android 7)
So, If you're using F8332, I can think that the problem is the Update for the F8332 Model Only.
