My Z1 will not seem to auto-connect to any WiFi I have saved, unless I turn WiFi off and back on again.
Bringing up the remembered list, and clicking connect on the network doesn't work either.
Both Stamina mode and location-based WiFi are turned off, and seem to have no effect on the issue.
Any help would be appreciated.
Thanks,
Brent
You appear to have covered most of the common causes of this issue so I would have to advise you to try a software repair:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
What are your thoughts about this forum? Let us know by doing this short survey.
Thanks for the advise, but that didn't seem to make a difference.
Any other thoughts?
Brent
