Vibretion problem
k7
Vibretion problem
I have an issue with my vibration for some time now... It's been almost 5-6 months i bought the phone and last month the vibration just stopped. A week after, it just came back on its own. And from that day the vibration still comes and goes on its own. Can anything be done for this ?
2 REPLIES 2
Samuel1
Hero
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
frantizsekk
Contributor
I have the vibration always switched off. Nothing will vibrate/shake my phone, it can only cause a potential damage to its guts, eats power and is good for nothing. The LED strip does the job very well.
