I dropped my phone last night my mistake and now the internal speaker volume has gone down and the clarity of the sound has reduced.
I know that there might an internal damage to the speaker but is there a way I can fix this at home instead of taking it to service center.
Prabhakar
Unfortunately I don't think it's a good idea to try to solve this yourself. I would recommend that you send this in to a service center for repair. I suggest that you raise this with your local support team to get further information Local support.
