Problem with Xperia SP
moinraza007
I am facing issue with my phone that it is getting off automatically when battery is little low like 25%,35% and not getting on, it vibrate when I try to power it on. It is not powering on even after put it on charging. I will get on only after charging of one hour or more charging.
I have not faced any such issue earlier, past couple of weeks I am facing this issue. My phone is around 10 months old.
Can anyone suggest what should be the problem or issue??
Regards..
Moin
2 REPLIES 2
TheSavage
Unfortunately my friend, that's not a common problem. Your best bet is to take your phone to a Sony assitance to see what's going on.
Perhaps someone here could know what it is, but I wouldn't count on that.
Wish you good luck with your problem.
Regards!
Hekado
I had a similiar problem with you... I reflashed my phone with pcc and that helped for me. If you flash remember to backup your data first Slightly_smiling_Face
