Pressing the power button gives very few options.
Is there a way to add "restart" to it?
Quick and simple answer is no - This feature is not available
Those are not few,you can turn off,take a screenshot and airplane mode.And down you can select ringtone mode.Practically,to restart you have either turn off/on the device or use the combination with power button and volume up to force shutdown the device.
I know I loved that feature on my S3...Maybe sony need to stick with making TV's and Cameras 😕
press power+volume up until phone vibrate three times
this is how to restart the phone
It will only turn off.
@Chrisx wrote:Pressing the power button gives very few options.
Just get Xposed Framework and install Advanced Power Menu module. Fixes everything.
