Mount SD Card not displaying in Storage
Dougie2
Is any other Z5 Premium owners having this issue. I cannot install a memory card in my mobile as there is no 'Mount SD Card' option in Storage.
5 REPLIES 5
Uliwooly
@Dougie2
Could you test a different SD card ? you might have to reformat the SD card.
Dougie2
I have tried 3 different cards (2 new ones). They are not registering and the mobile isn't giving a Format option.
Uliwooly
@Dougie2
That's quite odd, you could reformat the SD cards with your computer.
Jake-SonyXperia
Champion
Hi Dougie2,
What version of Android are you running? Also what do you see when you access Storage?
Dougie2
Marshmallow 6.0. Storage is showing - Apps, Videos, Audio etc and what memory they are using. Nothing showing for External Memory or any option to Mount a SD Card.
