[HELP] SMARTWATCH 2
suhayl
[HELP] SMARTWATCH 2
help me please with this
so i just recently bought a sony smart watch 2 and i put it in charge for 5 mins, i took it out and it shows the charging symbol and thats all it is, it wont on the SMARTWATCH and i tried putting it in my pc but it doesnt work, it says 'not recognized device'
so glad if anyone can help
1 REPLY 1
Alexander1
Champion
I suggest that you try to press and hold the power button for at least 10 seconds to see if the SmartWatch will respond. If not, I suggest that you take it back to the store or contact your local Xperia care team for more information:
http://www.sonymobile.com/global-en/support/contact-us/
