There's a guy who owns a single sim variant and got over 2000mA charge rate, while I own a dual sim one and only got 1556mA at maximum. Both we use QC 2.0 charger (mine has 18W 9V-2A) but we don't share the same result. Can you explain for me, Sony? Is dual sim the problem? Left side is E6653 and right side is mine.
@RyTek
I'm sure that they know some issue exists. But they will not acknowledge. Denial. Eventually they will make you believe that those are Z5 dual's design limitations. They will also not have any bench marks to compare agains't to check if our devices are within limits.
And worst of all, they official Sony rep doesn't respond on these threads. Even if they do, they follow the below algorithm:
1. I think you are not using quick charge.
2. I think you are running back groud applications
3. I think the power socket is not working
4. could be problem with cable
5. could be software issue-reinstall os.
6. take to sony service center
7. I think your device is hot.
8. Weak signal and heating due to that
For god sake, if a user is coming over to blog and typing some observation, they would have definitely checked all of the above and post here only if they are unable to resolve. I feel that this blog is just provides a false hope for solutions. Will not get any solutions and most of the people who respond are other users with minimal knowledge.
