On the HT-X8500 soundbar, how does one tell if a mode is on or off? Now, you can tell with some modes such as Voice, if the blue light comes up, you’ve turned it on and if the white light comes up, you’ve turned it off, same for Night, but how does one tell if Cinema and Music mode are on or off? Is it possible to tell or not?
Thanks for the help!
