Hi
Unfortunately, I am not able to update the firmware on my SONY Bravia KDL-55W805C
Current firmware: PKG2.257.0010EUA
I downloaded the latest firmware (v3.865 Sony Website) and put onto a USB:
- The update started and a white Led light started blinking on the front panel of the TV
- When the update finished, I went to Home - Settings - Help and the firmware was not updated (PKG2.257.0010EUA)
I tried inserting prepared USB into USB port 1, 2 and 3 and also created two copies of the update on, one of them renamed as 'upgrade_uploader.pkg' having no luck (PKG2.257.0010EUA).
When going to Home - Settings - Help - System software update - Check for a system software update - Update Now:
Please, does anyone know why this is occurring and how to fix it.
Tony
