Who Me Too'd this solution
Anonymous
Not applicable
Hi there
There are a few things you can try before contacting Support (of which they will get you to do anyway)
  1. Disconnect the BT box completely from the TV (lets remove a possibility)
  2. Ensure that you have the latest firmware installed.  See : HERE for more details.
  3. Perform a Factory Reset of the TV.  Instructions : HERE
If things still do not work after that, there is probably not much this forum can help you with.  Best to contact Sony Support : HERE
Let us know how you get on anyway - im curious to know :slight_smile:
Cheers
