Who Me Too'd this topic
theclac
Sound lag, delay with Bravia Sync ON
Hi there
I have a 42w805 and a htss360 sound setup
For the past few weeks I have been trying to get the sound correct.
When I turn the av unit off the sound becomes in sync again (sound through the TV speakers). When the sound system is on the sound lag seems to vary. Its best response is in game mode with all motion enchancements turned off
I have (today) turned off the Bravia Sync/Control options which has made a major difference, although there is a lag it is generally at 3ms. BUT now I can not control the sound through my tv. The av receiver is in a unit tucked away.
This never happened on my Panasonic (few years old) tv and have tried the Panasonic tv today and the sound setup works perfectly
I had similar issue with a friends hx805/853 (forget which one) where they had a non-sony amp (bought at the same time) and had similar issues. They had to get a (recent 2013) Sony amp instead and all worked ok
I can only assume that there is some data being transfered between the two items when Bravia Sync is on that will cause this lip sync issue. I really don't want a new amp as they are so big. If they did an alternative to the htss360 I would be happy to upgrade (even to the point of any other brand for a streamline av receiver)
Any suggestions for different hardware or settings would be greatly appreciated
