Using Walkman with non-Blutooth speakers
Mrs.P-D
Hi! I'm very new to Walkman, having just switched from an i-pod which decided not to work properly, so I'm having a complete change. None of my speakers are blutooth machines. I'm just wondering if I can safely connect the new Walkman to my existing speakers with a wire instead of blutooth? I mean wire it into the AUX port - I have a wire with headphone jacks on both ends - but I thought I'd check before buying new equipment. Thanks in aadvance for your help
2 REPLIES 2
Joe_Dohn
Specialist
It should work as long as the Walkman has a AUX (3.5mm) port and the speakers have the same.
Sonyvores
Contributor
yes you can no problem, just use the regular mini jack port for headphone on the walkman and it wil do the work
