sony nw zx100 connection to fiio q5s
marcoresearcho
hi community,
i've just purchased a fiio q5s and i'm hoping to use it with a cable connection to my sony walkman.
any information on getting the best sound from this combo will be very much appreciated.
1 ACCEPTED SOLUTION
Peter_S.
Hi Marco,
I think the only option is, to connect the fiio to the headphone output of the Walkman.
Cheers
3 REPLIES 3
Peter_S.
Hi Marco,
Cheers
Sonyvores
Contributor
to get the best from ZX100 and your portable dac is to use the digital audio out.
Fiio is selling a special sony connector to micro USB (Fiio L27) check out their website or amazon
marcoresearcho
Thank you for your reply Peter, i am using the bluetooth connection and i am surprised at how much better the sound quality is than when i connect it using the headphone output.
