Wireless Connection
hammer249
Wireless Connection
I have connected my VAIO notebook to my network, it is working fine.
the only problem is that the home desktop pc is running very slow while on the internet, mine however is running at the normal speed.
i have used a Belkin ADSL Modem with Wireless-G Router. i have used PPPoA protocol and have changed to PPPoE with no visible effect on either machine.
is there anyway that you can think of to speed up the connection of the home desktop which is connected directly to the router.
1 REPLY 1
masterix
Hi hammer249,
Try soft from www.tune-up.com - it might resolve much more problems on your computers....
Good luck
