Hi guys,
I changed my desktop from a VGC model to the new VA1 and kept the old WKB1 keyboard. I'd like to use the WKB1 keyboard with the VA1 as it is a better quality one than the one supplied but can i get it to work.. can I heck... it simply isn't recognised.
Is what I'm doing possible or do I have buy a USB receiver thingy for it? (don't see why as the VA1 has it all built in doesn't it?)....
Help - give me back my keyboard!!:smileycry:
Hi there and welcome to the forum.
Can u check if any buttons in the VA1 that is called " Connect " ? That's a button to find your wireless keyboard. Both in VA1 and Keyboard have to link up and you should be no problem ...
Hope everything fine... Try to find both "Connect" buttons and press to let them link it up.. hehe
Thanks for the reply, but i've already tried that - several times, including cold starting the computer.
I know the keyboard is fine and even shows the battery life left on the display..
