i#ve add a ram module to my vaio rx and the sytem
crashes.
the ram: pc2100 512 mb ddr266/184pin
in the vaio is allready a pc2700 256mb
samung module.
any ideas?
best regards buster
btw. is is the second module that i am trying.....
If you take out the original RAM and put the new one in by itself, what happens?
pc2700 & pc2100 won't work side by side
They run at different speeds and will cause problems as you have found out.
You may want to check whether your motherboard accepts PC2700 RAM in the first place
