Please Help me.I have a problem with my first Hard drive :(
CuteeJazz
Hi, :cool:
I wanted to restore my first hard drive but it doesn't work :angry:
I've restore the second part with the system of gestion.
But now after back up all my files on my new (second hard drive) I want to restore the first in NTFS for all part. I put the CD restore and I restarted the computer . The problem is that the CD rom is not reconized :cry: and I can't do anything :cry:
I have an other solution but it's risky :anguished:
Format the hard drive in the post of work :cry:
I don't want a solution like that because I have no back up to make it good.
If you have a solution please help me :smileyrolling_eyes:
Thank you for reply :cool:
15 REPLIES 15
kee-lo_
Use something like Norton Ghost, so you won't loose a thing.
CuteeJazz
Thank you Kee-Lo :smileygrin: you have all answers for all questions :smileygrin:
I'll search for this in google in order to know what it is and where I can find it :slight_smile:
CuteeJazz
I found a temporary solution which could be surely used for others. :smileygrin:
If you want to convert your hard drive in NTFS
It is necessary to go in the start menu /executer and to type in the register key:
convert x:/FS:NTFS
N.B:You can't convert NTFS in FAT :slight_smile: only FAT in NTFS :cool:
P.S:smileygrin:on't pay attention to mistakes :wink:
kee-lo_
Hi Cutee-Jazz,
Thanks for that tip that's great.
By the way, the UK edition of Windows XP "executer", is "Run".
As I haven't seen Windows XP in French I don't know all the terms.
CuteeJazz
Yes I made a mistake :laughing:
I should perform in english language :slight_smile:
:wink:
kee-lo_
Hehe no problems.
