Internet explorer problem
djwoody
Hi.
When i first go into internet explorer, an online casino pop-up comes on the screen.
Is there any way of stopping this, its becoming annoying.
Maybe a registry fix?
Hope you can help.
Chris
6 REPLIES 6
rich912
Contributor
Hi Chris,
Run your spyware removal tool. If you don't have one try Spybot S&D.
Go n-éirí an bóthar leat
djwoody
I have tried that, also tried Ccleaner and registry mechanic but still with no luck.
Any other ideas?
mdb
HI CHRIS TRY USING S7D SPYBOT.
Thalamus.
Champion
Download and run Adaware
Failing that if your firewall does not have the option for pop-up blocking a search on google for a popup blocker should provide you with a download link. :slight_smile:
Blencogo
Have you tried Control Panel>>Internet Options>>Privacy
At the bottom, check "Block Pop-Ups" and in "Settings" select "Medium" or "High".
You should also have a Pop-Up blocker in your Firewall.
:thinking:
kee-lo_
