I thought I should ask about this. Pretty much ever since iI had this laptop after a lil while of being on the casing of the laptop gets very hot, and the vents on the left side is very hot. is this normal. my gf has a NR38 and hers runs very cool, not stupidly hot like mine, ive got the laptop covered by extended warrenty thankfully, as i cant see that this heat is doing the inside any favours!
The FZ-Series laptops seem to run hotter than some other models.
Try using PC WIZARD and check the temeratures of the CPU, GPU and HDD and post them here for others to compare.
just watching a film atm, CPU temp both cores 78-79 celcius and GPU 77 celcius
Ok ill now turn the film off, because thats not very fair, ive let it settle for a few minutes
CPU is 65ish and GPU just under 70
That seems fairly normal to me.
Let's see what other FZ users say.
