Hi volks
When i use my laptop for serveral hours at home or at work i remove the battery pack bevor switching on, to save lifetime.
What do the pro's think about that? Does it make some difference?
Is there some kind of wearout on the battery pack whil running on electricity supply?
Kr,
Morph
Hi Morph,
you may find the following links on How to prolong lithium-based batteries and If I remove the battery & run from a power source will it lengthen battery life? of interest..
c o o l
thx m8!
You're welcome..
For anyone interessted...
It is possible to set the battery recharge to a smaller value than 100%. So you can save your batterys lifetime.
Open the Sony VAIO Control Center
Registerchart, Energy Savingfeature
Battery charging-function
There you have two modes: One sets the charging value to 80%, the other (better) one to 50%
Anyone knows where i could change the value 50% to 40% ?
Mayby within the registry somewhere?
cheers,
morph
m8, you are talking to a neurotic, i can't sleep until this is solved ^^
will post here when done...
cheers
morph
