- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a Vaio PCV-V1 all in one with Windows XP. There is no memory left so I'm looking to buy an external hard drive. The machine only has standard USB ports so it won't fit most hard drives currently on the market. Please can someone recommend a device I can use, or is it a question of buying a cable that will allow it to connect to a USB 2.0 or USB 3.0 hard drive?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Woodentrainforever,
I think your model has a PC card slot so the way forward is probably a PCMCIA to USB 2 cardbus. There are plenty on the market for less than £10.
http://www.amazon.co.uk/Belkin-USB-2-0-NOTEBOOK-CARD/dp/B000MFZ10C/ref=pd_sim_ce_2
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Rich
