Bravia KDL-42W705B sound but no picture
mox888
As the title says I have a KDL-42W705B with sound but no picture. We were watching when the picture scrambled...reduced to the top 6 inches of the screen and then disappeared.
There is still a backlight and sound but no picture. Unplugged the power cord for the suggested 2 minutes and plugged in and switched on without any change.
Anymore settings to try or is it call the maintainence man?
Thanks.
1 ACCEPTED SOLUTION
Anonymous
Not applicable
Hi there
It does sound like the TV needs a repair.
Its your description which indicates to me that its a hardware fault:
"We were watching when the picture scrambled...reduced to the top 6 inches of the screen and then disappeared."
Cheers
3 REPLIES 3
Anonymous
Not applicable
Hi there
Cheers
mox888
Thanks for your reply.
Yes did think that was the likely outcome. Just wanted to cover things I might not have tried.
Bluetoot
Could you get it fixed? Sounds like we are having a similar problem.
